1.3.0 - crop toolbar - selection ratio shortcut
XnViewMP 1.3.0
Windows10 (21H1), display resolution 3840x2160, dpi scale 150%
Viewer - crop toolbar
Selection's aspect ratio shortcuts work: A (Free) and D (Fixed ratio).
However, value in 'Selection' combobox does not change accordingly.
2. open image
3. press SHIFT-X to open Crop panel
Issue A
4. press D for Image Fixed ratio
value in combobox does not change to Fixed ratio
Issue B
4. select any fixed aspect ratio, eg 1:1
5. press A for Free
value in combobox does not change until you press mouse button and start selection
Issue C
4. select any units aspect ratio (cm/inch/pixel), eg 130x100 mm
value in combobox does not represent selected ratio, but changes to Free instead
Expected behaviour:
In all cases combobox shall change its value right after shortcut is pressed.
Related
Re: 1.3.0 - crop panel - selection ratio shortcut
user0 wrote: Thu Oct 06, 2022 10:39 am Issue A
Issue B
5. press A for Free
'Selection set ratio' is disabled during crop panel
Issue C
yes to be able to resize the selection
xnview wrote: Wed May 07, 2025 2:41 pm
Issue B
5. press A for Free
but A, D shortcuts work (as expected),
so combobox should reflect changes of aspect ratio via these shortcuts
user0 wrote: Thu Oct 06, 2022 10:39 am Issue C
right, but it should change to 'Fixed ratio' (instead of 'Free') as selection has fixed ratio
