1.3/1.3.1 - Pressing RETURN to enter folders/files doesn't work
Froyok
Post by Froyok »
Since upgrading to version 1.3.0 (and then 1.3.1) I cannot use the RETURN key on my keyboard to enter folders highlighted in the list. Using the RETURN key on my numpad works however. This seems to be a regression.
I looked at the reports currently around, and while I saw similar bugs I haven't seen one that was identical to the behavior I'm facing. Apologies if I'm creating a duplicate.
  • XnView: MP 1.3.1 64 bit (Oct 12 2022)
  • OS: Linux (5.18.19-3-MANJARO, X11)
Effect: Cannot open folder, see files
  1. Launch XnView MP
  2. Click in the file list
  3. Navigate in the list of files and folders with the arrow keys
  4. Press RETURN to open a file or folder
Actual behaviour (bug): Nothing happens
Expected behaviour: The file or folder is opened.
Additional informations:
  • Layout used is "Layout 7"
  • The right sidebar is always set to the "Preview" tab
  • Video of the bug:
    xnview_bug_return.mp4
  • OS language: English
  • Keyboard layout: French
Similar bug: viewtopic.php?f=104&t=44000
Froyok
Re: 1.3/1.3.1 - Pressing RETURN to enter folders/files doesn't work
Post by Froyok »
I'm noticing some other odd behaviors related to keyboard shortcuts, should I create another report ?
For example when pressing F2 to rename a folder, if I use SHIFT+T or BACKSPACE it will exit the renaming mode and go somewhere else or back a folder.
Was there a big refactor of the keybindings in 1.3.0 ? That would explain what I'm seeing. :?
Please check this post. It seems that the problem comes from xkeyboard
Froyok
Post by Froyok »
Thanks, I will check that out.
XnView MP is the only application I have that seems affected by this change surprisingly. I have other Qt app (old and new) that seem to work fine.
Froyok
Post by Froyok »
I reverted to an older version (of xkeyboard config) and that seem to have made everything work back again.
You can probably close this report. :)
