B2: Known 'RMB+mouse' bug - solution?
Dreamer
There is a known bug when using RMB+wheel / RMB+LMB / RMB+MMB - context menu appears when you release RMB.
But - if you move a mouse a bit before you release RMB, context menu does not appears.
Maybe it's the way to fix this bug, you could simulate this move, when actions above are performed.
XnView 1.82 <x>
XnView 1.82 <x>
Re: B2: Known 'RMB+mouse' bug - solution?
I'll try to fix itDreamer wrote:There is a known bug when using RMB+wheel / RMB+LMB / RMB+MMB - context menu appears when you release RMB.
Dreamer
Dreamer
Dreamer
Dreamer
Not fixed in RC2. I think it works sometimes (if I zoomed in few times), but I can't reproduce.Dreamer wrote:But you'll try to fix "FS lite - RMB+MMB"? It's not View FS.xnview wrote:YesDreamer wrote:Partially fixed, again:
Fixed:
FS lite - RMB+wheel
FS lite - RMB+LMB
Not fixed:
FS lite - RMB+MMB
Standard FS will be postponed, right?
Dreamer
Dreamer
Dreamer
Fixed.Dreamer wrote:RMB+MMB - fixed, but RMB+LMB doesn't work now and new - strange effect is shown (I'll start new topic).Dreamer wrote:No, with FS lite - RMB+MMB.xnview wrote:You have always the problem for FS lite - RMB+LMB?
Not fixed - postponed.FS standard - RMB+wheel
FS standard - RMB+LMB
FS standard - RMB+MMB
