1.4.0 MP: Windows 64 GPS crash [Solved]
rusitzky
Post by rusitzky »
XnView: MP 1.4.0 - 64 bit
OS: Windows 11 64bit
Choosing "GPS" tab in "Info" panel causes crash
Effect: Program crashes
(This may be a duplicate of topic 44447 - Affichage GPS sur version 1.4.0 du 12/12/2022 - but that's in french and I can't tell for sure.)
1. Open XnView
2. Choose a photo that shows the "GPS" tab in the "Info" panel
3. Click "GPS"
Actual behaviour (bug): XnView crashes
Expected behaviour: XnView shows GPS info
Note: Windows event viewer reports this:
EventID 1000 (Error):
Faulting application name: xnviewmp.exe, version: 1.4.0.0, time stamp: 0x6396ea03
Faulting module name: Qt5Core.dll, version: 5.15.11.0, time stamp: 0x6332aa78
Exception code: 0xc0000409
Fault offset: 0x0000000000020668
Faulting process id: 0x0xA8D4
Faulting application start time: 0x0x1D9101216C01921
Faulting application path: C:\Program Files\XnViewMP\xnviewmp.exe
Faulting module path: C:\Program Files\XnViewMP\Qt5Core.dll
Report Id: a7f15107-307b-4011-8176-73f5d60c8074
Faulting package full name:
Faulting package-relative application ID:
There's also an EventId 1001 which looks like it created a "WER" - let me know if you want me to upload / email that.
Thanks very much for your help.
-Michael
Re: 1.4.0 MP: Windows 64 GPS crash
Please try to download the package again, i've fixed it
rusitzky
Post by rusitzky »
Sorry, but it's still doing the same thing. I even tried uninstalling and reinstalling and still the same thing. I am using the "Setup Win 64bit" download link under "Installer for Windows".
rusitzky
Post by rusitzky »
As a follow-up, I tried downloading the Windows 64-bit zip version and that works fine, so I'm assuming it's an issue with the MSI (exe) packaging. Hope that helps.
-Michael
online.login
Post by online.login »
I'm using XnView 1.4.0 MP on Linux (Ubuntu 20.04) and I have the same issue. Is there a fix for Linux as well?
online.login wrote: Fri Dec 23, 2022 12:00 pm I'm using XnView 1.4.0 MP on Linux (Ubuntu 20.04) and I have the same issue. Is there a fix for Linux as well?
do you use the .deb?
online.login
henkux
Post by henkux »
Just downloaded and installed latest .deb on Linux Mint. Confirm crash after select GPS tab.
rmtk
Post by rmtk »
Crashed on Linux, too
The terminal messages:
######### CategoryModel :: checkAndSave()
QObject::connect: No such signal GPSMapWidget::reloadMap()
Could not find QtWebEngineProcess
Aborted (core dumped)
rmtk wrote: Sat Dec 24, 2022 3:29 pm Crashed on Linux, too
Please download again the package, i have fixed it
henkux
Post by henkux »
After new download and reinstall (same version), GPS tab is shown as expected.
Thanks!
aapeli
Re: 1.4.0 MP: Windows 64 GPS crash [Solved]
Post by aapeli »
I'm running fedora 37 and XnViewMP 1.4.0 64bits and this is still occuring. I have tried uninstall/reinstall, but flathub version keeps crashing while clicking GPS tab. I can see from about, that this version was compiled Dec 12 2022, and there is no newer version available,
aapeli wrote: Sat Dec 31, 2022 7:42 pm I'm running fedora 37 and XnViewMP 1.4.0 64bits and this is still occuring. I have tried uninstall/reinstall, but flathub version keeps crashing while clicking GPS tab. I can see from about, that this version was compiled Dec 12 2022, and there is no newer version available.
Unfortunately, Pierre cannot produce Flatpak versions himself, so when an issue is fixed there may be a delay -- sometimes in the past quite a long delay -- before the new version is available in that format... :(
Are you able to install one of the other downloads?
aapeli
Post by aapeli »
cday wrote: Sat Dec 31, 2022 8:36 pm
No, there is only one version available. Anyway, this is not a major issue for me, I can wait for update. and other features of xnviewmp are working fine. Maybe I could install new version somehow, but for me this is currently not a showstopper. I can continue with 2022 pictures categorization!
