Using Linux, Arch XFCE 4.18. I cannot find anywhere to adjust colors that affects SCI.
Noted: It seems to change size as I move the cursor over pixels. As if it is white text on white background.
See attached image. (edited: "about screen" pasted in)
Show Color Information only shows white square [Solved]
nulldevice
Re: Show Color Information only shows white square
In Linux Mint Cinnamon 20, XnView MP 1.4.0, when I check View > Show colour information I see this:
That is with default settings, I am not sure whether there is a control for text colour, I doubt it.
Is your screenshot showing Help > About a composite image??
nulldevice
Yes. I noted this in the Edited part of my original post. Just to show the information.Is your screenshot showing Help > About a composite image??
Looking at your image, the aspect ratio of the rectangle looks the same as in mine, but the background colour in yours is white rather than light yellow.
I am afraid I have no idea of the possible cause, I can only confirm that it works correctly in Linux Mint, other than to wonder if there might possibly be .ini settings involved which seems quite unlikely.
You also reported that your rectangle changes size as you move the cursor?? You are, stupid question, using View > Show colour information Ctrl-Shift-I?
nulldevice
yes, size changes every so slightly on the x axis mostly. ( i assume this is just adjustment from the RGB values of low range to high range going from 0,0,0 to 255, 255, 255 (wider) But I don't know. I don't consider this (the rectangle size) a bug, just reporting what ever I can, so I can find a way to see the info, which I do consider a bug
yes, as the topic title indicates ;>
Very strange, if you would like to try an earlier version this is the link: Older versions.
If you didn't check the checksum of your download you could possibly try repeating the download. Or you could possibly try an alternative Linux download of 1.4.0, in a situation like this trying anything you can think of sometimes provides an unexpected insight...
nulldevice
I tried using both packages in the AUR (standard and system-libs) both have the white rectangle.
fwiw, launching from console spews this:
MDK 0.15.0 (git e8c668a) - Multimedia Development Kit. Copyright (c) 2016-2022 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: Linux x86_64; Clang14.0.6 GCC4.2.1; libc++14000; 15:26:29 Aug 23 2022
==> 1,000000 1,000000 108,887533 96,004154 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1568 900
w.init
w.start
libpng warning: iCCP: known incorrect sRGB profile
QObject::connect: No such slot AbstractViewWindow::onPagePrevious()
##PB connect <1onPagePrevious()>
QObject::connect: No such slot AbstractViewWindow::onPageNext()
##PB connect <1onPageNext()>
QObject::connect: No such slot AbstractViewWindow::onPageFirst()
##PB connect <1onPageFirst()>
QObject::connect: No such slot AbstractViewWindow::onPageLast()
##PB connect <1onPageLast()>
QObject::connect: No such slot AbstractViewWindow::onUseSmooth()
##PB connect <1onUseSmooth()>
QObject::connect: No such slot AbstractViewWindow::onNormalize2()
##PB connect <1onNormalize2()>
QObject::connect: No such slot AbstractViewWindow::onAlign()
##PB connect <1onAlign()>
MENU install : 0x269a310
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 183, 226, 227, 255'
@@ 37169944
Create window finished
==> 1568
ThumbLoaderThread :: stop()
############### UPDATE MENU ############
nulldevice
update:
"FIXED"
I nuked the entire xnviewmp folder in .config.
Now it works. (I just have to re-do all my settings...)
Perhaps an older setting was in conflict with a newer version of xnviewmp.
"FIXED"
yellowdolphin
Re: Show Color Information only shows white square [Solved]
Not quite fixed:
The bug is triggered by choosing Darkscheme or Blackscheme at first run. Can be undone by setting "style=-1" in ~/.config/xnviewmp/xnview.ini
