PDF file does not open -- 'File can't be loaded' [Solved]
oiner
Post by oiner »
Subject: 1.4.0: crash when indexing pdf file
XnView: MP 1.4.0 64 bit
OS: Windows 10 64bit
opening a certain pdf document will crash XnView MP 1.4.0
Effect: Program crashes
1. save M7310v1(EU)_DS.pdf file (attached)
2. open this file in XnView MP
Actual behaviour (bug): Program crashes :bug:
Expected behaviour: Don't crash
M7310v1(EU)_DS.pdf
This file will crash XnView 1.4.0 64bit on Windows 10
(511.39 KiB) Downloaded 236 times
Re: crash when reading the attached pdf file
Opens normally in multiple other PDF viewers, but confirmed not in XnView MP: no crash but 'File can't be loaded' message.
Occurs even with File > Format settings... > PS/PDF tab -- Read tab -- PDF -- Ignore read errors selected.
The file properties show it as having been produced in Adobe Illustrator CC 2017, so it should be valid.
This situation has occurred occasionally over a quite long period, and I'm not sure that any explanation has ever been found... :?:
It should at least provide a test file for Pierre!
Re: PDF file does not open -- 'File can't be loaded'
This problem is supposed to be fixed in XnView MP 1.4.1. Please check and confirm the bug fix here.
ckit
Post by ckit »
Bug Fix Confirmed with XnViewMP 1.4.2, M7310v1(EU)_DS.PDF opens via Browser mode into View mode is Perfect and "Drag and Drop" from XYplorer to XnViewMP View mode is Perfect!
ckit wrote: Thu Feb 09, 2023 6:58 am Bug Fix Confirmed with XnViewMP 1.4.2, PDF opens via Browser mode into View mode is Perfect and "Drag and Drop" from XYplorer to XnViewMP View mode is Perfect!
Confirmed using the test file above? :D
ckit
Post by ckit »
cday wrote: Thu Feb 09, 2023 7:26 am
Yes, of course
Re: PDF file does not open -- 'File can't be loaded' [Solved]
Thank you, it is good that this previously unexplained issue which has arisen occasionally over a long period is now resolved... :D :D
