Crash of xnview if not starting as administrator
Gerold
Post by Gerold »
till now i used xnview as afministrator without problems.
Because of security gain i switched all users to not administrators users. But now I cannot start xnview anymore. As admin, xnview runs still.
AppName: xnview.exe AppVer: 1.80.0.0 ModName: ntdll.dll
ModVer: 5.1.2600.2180 Offset: 00001010
XP latest version.
Please allow not admin users to work with xnview!
Re: Crash of xnview if not starting as administrator
Gerold wrote:Hello,
XP latest version.
Please remove xnview.ini from program folder (a known issue)
Norbert
Post by Norbert »
xnview wrote:
Gerold wrote:till now i used xnview as afministrator without problems.
Because of security gain i switched all users to not administrators users. But now I cannot start xnview anymore. As admin, xnview runs still. [...]
Hi!
I had the same problem with the new 1.82.1 (Windows XP Home SP2, XnView installed over 1.80.3-installation).
XnView crashed after I tried to open the MyPictures-folder located at "D:\Eigene Dateien von Norbert Glauner\Eigene Bilder" even if the folder was empty.
If I started XnView with Admin-privileges it was not crashing with this folder. If the MyPictures-folder is configured as start-folder it has the same effect described by Gerold.
Removing the xnview.ini does not help. If you install the 1.80.3 over 1.82.1 the older version has the same problem. Deinstallation of XnView, removing the xnview.ini manualy and installing the latest version again solved the problem for me.
Best regards,
Norbert
Hi!
Yes, the problem exists if you have an old .ini in XnView folder...
plut0
Post by plut0 »
I am having the same problem and unable to fix it. Anymore suggestions?
plut0 wrote:I am having the same problem and unable to fix it. Anymore suggestions?
Have you removed xnview.ini from xnview folder?
plut0
Post by plut0 »
Yes I removed the xnview.ini file and it didn't help. The program crashes about 8/10 times that I load it.
plut0 wrote:Yes I removed the xnview.ini file and it didn't help. The program crashes about 8/10 times that I load it.
And the cache folder?
In user Application Data/XnView, do you have the cache and xnview.ini?
plut0
Post by plut0 »
No, I do not have the xnview.ini or cache directory in Application Data/XnView. I coped the ini file over and created the cache directory but it still crashes constantly.
plut0 wrote:No, I do not have the xnview.ini or cache directory in Application Data/XnView. I coped the ini file over and created the cache directory but it still crashes constantly.
Could you disabled options/browser/Cache, and remove all xnview.ini from your computer?
plut0
Post by plut0 »
Tried this but it still crashes almost everytime. Anymore ideas?
Other Shell ?
—> plut0
:) Hello !
• Just an idea : Are you using any third-party Shell alternative application ?
- This causes often many issues…
:mrgreen: Kind regards,
plut0
Post by plut0 »
I had ACDSee32 installed but I removed it and still have this issue.
I meant---
—> plut0
:) Hello !
• Well, this app. has a Shell extension, but I meant an Explorer Shell replacement.
- Some are great, but even the best ones could cause issues with some programmes, i.e. TC-users having such “Shells” got similar "buggy" behaviours, up to be unable to run the soft ! Here, I don't use any…
:mrgreen: KR
plut0
Post by plut0 »
Then no, I don't use one.
