Thumbnail and Preview not displaying correctly
kiwichick
Post by kiwichick »
Can someone please tell me what is happening with these files? The first one is an xcf file used by GIMP and the other two are pfi files used by PhotoFiltre. They all contain layers.
1) XCF file:
XnView displays one layer as the thumbnail but a different one as the preview.
2) PFI files:
The first pfi file is being treated as an 'other' filetype whereas the second one is recognised as a filetype.
3) Why are the xcf files listed before the pfi files when I have the sort order as ascending?
Re: Thumbnail and Preview not displaying correctly
could you send me the files?
kiwichick
Post by kiwichick »
xnview wrote: Wed Feb 15, 2023 7:06 am could you send me the files?
Yes, absolutely. How would be the best way to do that?
contact at xnview dot com
kiwichick
Post by kiwichick »
xnview wrote: Mon Feb 20, 2023 8:03 am contact at xnview dot com
Thanks Pierre, have sent them through.
kiwichick wrote: Wed Feb 15, 2023 2:51 am 1) XCF file:
Thumbnail doesn't use layers but embedded image so you can see a difference
2) PFI files:
Yes i'll check
XCF has file type 'Gimp', and PFI 'Photofiltre'
kiwichick
Post by kiwichick »
xnview wrote: Wed Feb 22, 2023 9:38 am Thumbnail doesn't use layers but embedded image so you can see a difference
Thanks, that explains it.
Yes i'll check
Thanks, I look forward to hearing about what you discover.
Ah yes, my mistake, I didn't realise I was sorting by Type instead of Name.
kiwichick
Post by kiwichick »
2) PFI files:
Yes i'll check
It's been nearly two months, just wondering if you've checked into this issue yet?
kiwichick
Post by kiwichick »
Still waiting for an update but, in the meantime, I've discovered the same strange issue with PDF files. Here I have two - one displays a thumbnail and the other doesn't.
