1.4.4 - levels - grey pointer has no limits
XnViewMP 1.4.4 64bit
Viewer / Batch convert - Levels...
Grey pointer is not limited by black/white pointers (as it does eg in Photoshop)
2. open image
3. press L to open Levels...
4. manually drag black pointer to the right
5. manually drag grey pointer to the left past black pointer
grey pointer will not stop at black pointer and go past it (same issue with white pointer)
6. manually drag black pointer to the left
grey pointer will go offscreen
Related
masterjp
Re: 1.4.4 - viewer - Levels grey pointer has no limits
Post by masterjp »
At the first time I tried it without reading your instructions. :-(
You are right. Now I can reproduce your problems and can confirm both bugs.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: 1.4.4 - levels - grey pointer has no limits
1.5.0b1
  • D
    - it is still possible to move one pointer behind another by manually editing values
  • E
    - range's scale for grey pointer feels denser on the left when changing it manually
user0 wrote: Sat Jun 17, 2023 6:31 am
  • D
Ok will be fixed in b2
  • E
it's normal, you have range from 10 to 1 for the first half, and from 1 to 0 for the second half...
xnview wrote: Mon Jun 19, 2023 10:46 am
  • D
wait.. looks like false alarm here
in ps/lr its possible to drag one pointer past another, making negative image
maybe its worth to make the same (currently its not possible to manually drag pointers past each other in xnview)
