I opened a picture and saved it with the 'save as' dialog.
You can choose the file format in the following dropdown menu:
The avif file format is available in the extension AVIF and also in HEIC.
I think it is better to remove the extension *.avif at HEIC/HEIF format.
1.4.4 Save as dialog - duplicate file extensions at different file formats
masterjp
Re: 1.4.4 Save as dialog - duplicate file extensions at different file formats
yes, currently i test loading avif with HEIC library
I guess it describes this behaviour:
1.4.4 - batch convert - avif saves as heic
yesuser0 wrote: Wed May 03, 2023 7:52 am I guess it describes this behaviour:
This problem is supposed to be fixed in XnView MP 1.4.5. Please check and confirm the bug fix here.
