Batch convert - move controls between Output and Settings
XnViewMP 1.4.5 64bit
Batch convert
minor UI adjustments
  • move 'Use multiple CPU Cores' from Output to Settings tab
  • move 'Beep at the end of process' from Settings to Output tab (to 'After conversion' group)
    OR
    move whole 'After conversion' group from Output to Settings tab, as Output is about destination/filename/format, but not bout what happens after
  • realign controls on Settings tab to the top as there is some regression
Related
Re: Batch convert - move controls between Output and Settings
user0 wrote: Fri May 12, 2023 6:41 pm
Not sure
done in 1.5.0
xnview wrote: Tue May 16, 2023 3:35 pm
Not sure
if its "core per file" and not "coreS per file" - it has some sense to keep this setting in Output tab,
but to my taste Output tab shall be only about "what(filename/format)/where(folder/etc..)", not "how", especially if there is Settings tab
