Extract Frame Or Save Frame (it Crashes The Software Any Way)
Post by Hakim Antoine Said »
Hello 8)
When i Right Mouse Button Click, it Crashes The Software :?
Always The Software Crashes With Any Frame That i Want To Save From A Video :shock:
Extract Current Frame (it Crashes The Software)
The Same For.... Save Frame As (it Crashes The Software)
This bug drives me crazy :mrgreen:
Always Keep Going :wink:
Re: Extract Frame Or Save Frame (it Crashes The Software Any Way)
i can't reproduce, you can always reproduce?
xnview wrote: Thu May 25, 2023 7:30 am i can't reproduce, you can always reproduce?
Hi Pierre :wink:
YES
i Can Reproduce it Always
it Crashes The Software Any Way At Any Time, ALWAYS :!:
it is Literally impossible To Capture Any Frame From Any Video, Always Craches, Always
do you have sent the crash dump?
xnview wrote: Fri May 26, 2023 5:54 am do you have sent the crash dump?
i Tried Again And it Didn't Send Either
Also... Again i Tried To Save The Frame From The Video in Both Ways, And XnView Always Crashed
There is No Way To Make it Work, it Always Fails :!:
:shock:
when you send the crash dump, please set an email and some text to this issue?
xnview wrote: Sat May 27, 2023 11:19 am when you send the crash dump, please set an email and some text to this issue?
Of Course i Do Pierre :wink:
But it Does Not Work
i Want To Save Screenshots From Videos But i Definitely Can't...
XnView Always Crashes, No Matter What, it Always Crashes
it's Literally impossible To Capture Videos
i Have To Use Another Software For Making Those Tasks
:shock:
i can't reproduce, tell me when you have sent it
xnview wrote: Sun May 28, 2023 6:25 am i can't reproduce, tell me when you have sent it
i Tried Again.... When i Click Upload, it Seems Not Working, i Don´t Know Pierre
i Don´t Know Why You Can't Reproduce it, Can You Save Screenshots From Videos :?:
i Tried But Always Crashes Any Way, Any Time
Again... Extract Current Frame (it Crashes The Software)
it is Literally impossible For Me To Capture Any Frame From Any Video, Always Craches
Are You Sure You Can Reproduce it Without Crashing :?:
I'm still having the same bug and it still hasn't been fixed :shock:
it is Literally impossible For Me To Capture Any Frame From Any Video, Always Craches, Always :!:
This bug drives me crazy :?
please Pierre fix this bug
Hakim Antoine Said wrote: Mon Mar 11, 2024 8:38 am This bug drives me crazy :?
i'm not able to reproduce, i've tried on 3 computers :?
Hello Pierre :wink:
how odd
every time I try it, it ALWAYS fails me
Does it always work for you every time you try?
Doesn't it give you any errors?
Hakim Antoine Said wrote: Wed Mar 13, 2024 8:27 am
yes, never failed
yes, never failed
it's really odd
I just tried it again, and nothing, it always fails
I even tried it with administrator rights and it also fails
I tried it with more than 40 videos, and nothing!
I do not know what else to do
thanks for staying tuned and helping Pierre :wink:
Hakim Antoine Said wrote: Wed Mar 13, 2024 9:34 am I tried it with more than 40 videos, and nothing!
Have you tried sharing your videos with Pierre?
xnview wrote:
side note about XNF file handling
  • XNF thumb is visible in Browser and image can be opened in other apps
  • when XNF opened in Viewer
    - it shows 1st frame of source video
    - player bar is visible at the bottom and plays source video if ▶ pressed
  • when XNF opened in Viewer, but source video file has been renamed
    - no any image is visible, just black screen and player bar at the bottom
    - app hung once when I opened XNF from Browser via doubleclick
