yuv16 format supported?
Post by Guest »
hi
does anybody know how i can open files with the ending .yuv16
thanks
thomas
Re: yuv16
Anonymous wrote:does anybody know how i can open files with the ending .yuv16
Try to rename it in .yuv?
tonau
Re: yuv16
Post by tonau »
Hi Thomas and Pierre,
.yuv and .yuv16 are different format.
(YUV16 is not as common as YUV.)
YUV16 can be opened by DVS products, Avid DS and etc.
Re: yuv16
tonau wrote:Hi Thomas and Pierre,
Do you know the format?
Post by Guest »
Do you know if there is any freeware to view .yuv16
Thomas
Anonymous wrote:Do you know if there is any freeware to view .yuv16
Could you send me a sample? Which software create this file?
tonau
Re: yuv16
Post by tonau »
Hi Thomas,
I have hoped to find a free YUV16 viewer, too.
But I haven't yet. (It always works for expensive HW+SW systems...)
If I find anything, I'll let you know.
Hi Pierre,
Unfortunately, I don't know about the format detail. But I can provide the sample files. I'll send a message about them to you by e-mail.
Re: yuv16
tonau wrote:Unfortunately, I don't know about the format detail. But I can provide the sample files. I'll send a message about them to you by e-mail.
Yes please
CaptainSkol
Re: yuv16
Post by CaptainSkol »
tonau wrote: YUV16 can be opened by DVS products, Avid DS and etc.
Hi, i am currently working on down/uploading images from/to a DVS Prontoserver under OSX. Download works fine but upload is displayed by the Server with fields separated although the uploaded .yuv file created by nconvert looks fine.
Is there an option to control this ?
Is that a problem of the mentioned YUV16 format ?
Is there anybody out there who has successfully worked this out with a DVS product ?
Flintz
Post by Flintz »
*bump*
I ran exactly into the same problem: having *.yuv16 and *.yuv10 files here and absolutely no way to view them with any tools whatsoever.
Does anyone have a hint? I need to view the original frames to ensure our conversion doesn't introduce errors :-(
Flintz wrote:*bump*
Flintz
Post by Flintz »
sent you a ICQ message
