BIG BUG = IPTC Replaces # with 0
BuckSkin
Post by BuckSkin »
I don't know how long this has been going on, hopefully just since I switched to the latest version.
In the IPTC Editor, no matter where I may have the number symbol #, IPTC replaces it with 0 (a zero).
This holds true in any field I have checked.
For instance, I wish to use "GATX 3-bay Covered Hopper #GACX 121869" and instead I get "GATX 3-bay Covered Hopper 0GACX 121869"
I made this test to see if the problem was only with the # symbol or with all symbols:
TEST $ # @ * % ! ? / \ [ ] { } TEST
I pasted this in every field and the results were the same in all of them:
TEST $ 0 @ * % ! ? / \ [ ] { } TEST
I just now caught this; I hope it hasn't screwed up thousands of my images and only a few dozen.
mudo_j
Re: BIG BUG = IPTC Replaces # with 0
Post by mudo_j »
Unluckily, I can confirm this. (Windows)
BuckSkin
Post by BuckSkin »
mudo_j wrote: Wed May 24, 2023 12:58 pm Unluckily, I can confirm this. (Windows)
Thanks for checking and confirming.
mudo_j
Post by mudo_j »
It does not happen with version 1.4.3, it was introduced in 1.4.4.
BuckSkin
Post by BuckSkin »
mudo_j wrote: Wed May 24, 2023 1:07 pm It does not happen with version 1.4.3, it was introduced in 1.4.4.
Thank goodness for that; one less knot in my belly.....
mudo_j
Post by mudo_j »
With 1.5.0 beta 1, this looks to me to be fixed, when using Edit IPTC, but is still there with Edit XMP - both set to Mode: XMP, update or create IPTC-IIM.
(Windows 10, fresh configuration plus some needed settings)
ok will be fixed in b2
mudo_j
Post by mudo_j »
The additional issue with Edit XMP was fixed in b2, as it was meant to be. In b3, this is still OK, so it could be considered as fixed, I believe. Only tested on Windows.
BuckSkin
Post by BuckSkin »
mudo_j wrote: Sat Jun 24, 2023 7:20 pm The additional issue with Edit XMP was fixed in b2, as it was meant to be. In b3, this is still OK, so it could be considered as fixed, I believe. Only tested on Windows.
Thank you for testing this issue.
I just now got around to checking it in beta 1 and was unaware that I was behind in my versions; again - Thank You.
