App UI - menu structure - Image - reshuffle items
XnViewMP 1.4.5 64bit
Viewer - image menu
few minor grouping changes
Suggestion A
  • rename Swap to "Swap color"
    - also rename "Swap component" in Batch convert to "Swap color"
    • actually if its acceptable to rename it to "Swap channel" everything can be grouped under single Channel item
  • move "Remove alpha chnnel" below "Extract channel" item
  • move Offset.. close to other Transform items (Rotate, Mirror)
  • move Draw... on top of group items
Suggestion B
maybe move "Edit colormap..." right below "Change color depth..." as they are related items
Related
Re: App UI - menu structure - Image - reshuffle items
done in 160
are you sure you don't need a separator between "Change color Map" and "Map"?
user0 wrote: Thu Sep 28, 2023 6:26 pm are you sure you don't need a separator between "Change color Map" and "Map"?
right
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
