1.4.5 - viewer - metadata - label/rating not show
XnViewMP 1.4.5 64bit
Viewer - metadata
test image has xmp rating (4) and color label (orange)
however, Viewer does not show them neither in Info, nor in top-left/right corner when file opened via double-click
it only shows after:
- press Enter to switch to Browser mode
- close image tab
- open from Browser
now rating and label are shown
ps. Catalog is disabled
Re: 1.4.5 - viewer - metadata - label/rating not show
try to update catalog from file, it works correctly
but Catalog is disabled as I do not use it
with catalog disabled i can't reproduce
hm.. I have 100% reproducibility
these appears only if image opened from Browser
right when opened from windows explorer, rating/label are not here
fixed in 160
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
issue seems to occur from time to time
settings:
- default, except Catalog is disabled
to reproduce:
1. open test file via double-click from win explorer
2. close xnviewmp
3. repeat steps 1,2 ~5 times
at least few times out of 5 tries there is no metadata loaded in Viewer (but Browser always loads)
test file:
  • xmp (generated by Bridge)
    xmp.zip
    (1.9 KiB) Downloaded 199 times
