Slideshow: Delete key, option to change resampling algorithm
Post by Guest »
First I must say XnView is fantastic! I especially love the ability to very quickly create a slideshow from a folder and all its subfolders.
I often find a bad image that needs deleting when running a slideshow. The ability to delete the current image by pressing a key, followed by confirmation dialog window, would be very helpful.
Xnview already has many different resampling algorithms for resizing an image. It would be a great improvement there was an option to chose the same algorithms for the slideshow! I know that there is already an option to chose "high quality" (=bilinear?), but why not have the others also, allowing more choices between quality and speed? ACDSee, although inferior in many other aspects, has bicubic as standard for resizing and unfortunately this means the Xnview compares unfavorable when doing a quick evaluation. Having the ability to choose between all the algorithms already implemented would really differentiate Xnview from all other viewers!
Re: Slideshow: Delete key, option to change resampling algor
Anonymous wrote:First I must say XnView is fantastic! I especially love the ability to very quickly create a slideshow from a folder and all its subfolders.
Thanks
There is another thread wbout this request
Ok
qda
Post by qda »
good suggestions
