The cropped image thumbnail cannot be updated
alee001
Post by alee001 »
I found a bug, reproduce step as following:
1) Select any picture from thumbnail
2) Double-click to enter editing
3) Select range to crop
4) Exit editing picture and save then overwrite it
Regardless of pressing F5 to update or restart the program, the thumbnail is still the previous picture
XnView MP Windows
Version 1.4.5 64bits (May 10 2023)
Re: The cropped image thumbnail cannot be updated
alee001
Post by alee001 »
xnview wrote: Wed Jul 05, 2023 8:34 am could you send me a sample file?
alee001
Post by alee001 »
I don't know if there are a few file format problems, but I tried other JPG files and it works fine.
not a screenshot but a sample file
alee001
Post by alee001 »
xnview wrote: Fri Jul 14, 2023 9:58 am not a screenshot but a sample file
The following two image examples are cropped (such as half) and there will be a thumbnail problem after saving.
right it's a known issue when saving embedded thumbnail failed
alee001
Post by alee001 »
xnview wrote: Sun Aug 20, 2023 7:42 am right it's a known issue when saving embedded thumbnail failed
Hopefully the next version will improve.
