b3: [bug] aborting rename operation by selecting other folde
Locked
FlorianH
Post by FlorianH »
In browser file list...
1) rename file (edit mode with textbox activated)
2) change folder by selecting other folder in treeview
-> xnview crashes
Nothing here
:) Hi !
- I can't reproduce this, as well with "List" as with "Thumb-nails" as display…
- Under XP-Pro SP1
:mrgreen: VG
Xyzzy
Post by Xyzzy »
Confirmed in b3.
X.
FlorianH
Re: Nothing here
Post by FlorianH »
Clo wrote:- I can't reproduce this, as well with "List" as with "Thumb-nails" as display…
Hi Clo,
thanks for testing. Now i noticed, that i can't reproduce it all the time. Could you please try the following:
1) prepare one folder with
- file(s) - to rename
- subfolder 'new folder (0)' - must have parentheses in name!
2) delete ini and open xnview b3 and maximize xnview
3) in browser (view as thumbnails or whatever you want) select file and rename it (press F2)
4) in treeview select subfolder 'new folder (0)'
Can you reproduce now?
Thanks,
Florian
BTW: XP-Pro SP2
Xyzzy
Post by Xyzzy »
Happens not always, but the problem is true, see:
http://img270.imageshack.us/my.php?imag ... ash7qo.jpg
Note items selected in file list and tree.
X.
ckit
Post by ckit »
Took me a long time to reproduce this one.
My Steps:
1. Single Click on selected "Nero Exit 7.jpg" to rename but don't do anything!
2. Now click on "Clips" folder in Treelist and crash!!!
I also have "Auto Collapse" enabled.
I could only get this to work on a folder full of WMV video clips?
Anyway I now have a Dr Watson log of it....
function: <nosymbols>
0041f43f 81c420060000 add esp,0x620
0041f445 c3 ret
0041f446 8b4d10 mov ecx,[ebp+0x10] ss:00c2920e=????????
0041f449 8b150cd06500 mov edx,[0065d00c] ds:0065d00c=00b252a0
0041f44f 8b04ca mov eax,[edx+ecx*8] ds:02ac7208=00000010
0041f452 8b0d04d06500 mov ecx,[0065d004] ds:0065d004=02ac7208
0041f458 8d3440 lea esi,[eax+eax*2] ds:0009000b=????????
0041f45b c1e603 shl esi,0x3
0041f45e 2bf0 sub esi,eax
0041f460 c1e605 shl esi,0x5
FAULT ->0041f463 f6040e10 test byte ptr [esi+ecx],0x10 ds:02ac7208=10
0041f467 0f84b2010000 je 0041f61f
0041f46d 50 push eax
0041f46e e84d010100 call 0042f5c0
0041f473 8b1504d06500 mov edx,[0065d004] ds:0065d004=02ac7208
0041f479 03f2 add esi,edx
0041f47b 56 push esi
0041f47c e85fb20000 call 0042a6e0
0041f481 8b84243c060000 mov eax,[esp+0x63c] ss:0012efcc=0043d028
0041f488 50 push eax
0041f489 e822bd0000 call 0042b1b0
0041f48e 83c40c add esp,0xc
FlorianH
Post by FlorianH »
ckit wrote:Took me a long time to reproduce this one.
Yes, i know. It took me minimum half an hour (after Clo destroyed my illusion, that it is a simple bug / simple to reproduce :)).
ckit wrote:My Steps:
So perhaps my second posting with my steps is not right/not the only situation to reproduce it. Just a few questions:
1) Did you try with xnview.ini renamed?
2) Was xnview maximized?
3) Did you try with 'auto collapse' disabled?
4) Is there something special about yout file/folder situation?
5) Can you reproduce it all the time or just sometimes?
I can't test right now, because i'm on a mac - and there is no xnview beta...
ckit
Post by ckit »
No I haven't tried deleting the INI and I won't either.
Yes, XnView is maximised.
Disabling "Auto Collapse" didn't change anything, it still crashes.
Yes, I can reproduce "my method" 100% of the time.
FlorianH
Post by FlorianH »
Seems to be fixed in RC1. Can anybody else test and confirm?
Xyzzy
Post by Xyzzy »
Played with it for a few minutes and didn't get crash.
X.
Locked
