While I have Settings > General > General > Rotate images according to EXIP orientation tag checked, images do not rotate to the correct position when I scan through them. I guess I am missing something (to get automatic rotation to correct position)!?
Hans L
Automatic rotation to correct position
Re: Automatic rotation to correct position
it should, could you send me a sample file in the wrong position?
Hans L
Pierre, one such file attached. Thanks!/Hans L
there is no orientation field in your image
Hans L
Okay, Pierre, I understand. Now, I read quickly about orientation and EXIF on line, but must conclude that the articles were written by very bad AI
So, let me just ask two things: where would the orientation field have been in my image if there had been one? And what determines whether there would be an orientation field or not?
Thank you!
Hans L
Thank you!
Hans L
EXIF:Orientation is the field
Hans L
Thanks!
Hans L
Hans L
