XNView MP Crashes When Editing IPTC Info
Darkness
Post by Darkness »
Hi, I recently built a new PC and installed XNView MP.
I seem to have an issue whereby if I go to edit the IPTC tags on an image, the program just hangs. As soon as I click Edit IPTC. The only thing I can do is to go to Task Manager and end the task. It's strange as I had no issues on my old PC.
Tried older versions and it seems to happen on that too. Currently running the latest 1.52.
Re: XNView MP Crashes When Editing IPTC Info
on jpeg files?
Darkness
Post by Darkness »
Yes, on JPEG.
the crash occurs before the dialog box is displayed? on every jpeg files? Do you have sent the crash dump with crash dialog?
Darkness
Post by Darkness »
Yes, before the dialog.
I can't find any crash dump files but I can see errors in the windows log:
i can't reproduce, could you send me your xnview.ini?
Darkness
Post by Darkness »
Here it is.
I deleted that file, and it's recreated it and it's working fine now.
Definitely something wrong in my ini file then.
I can't reproduce. Could you try to use your xnview.ini but remove [iptc] section?
