Program Settings are being reset after restart [Solved]
nictau
Post by nictau »
XnView: MP 1.52 64 bit
OS: Windows 10 64bit
Our program settings are being reset after every program start.
So, every setting has to be set again. Very annoying!
Re: Program Settings are being reset after restart
have you opened multiple instances? as the last closed one will overwrite .ini file with its settings
nictau
Post by nictau »
No, just one instance!
Where are your setting saved in Tools > Settings > Integration tab?
And are you accessing XnView MP from a user or an admin account?
I'm in Linux for multiple reasons, but wonder if there might be a file access rights issue in some configurations?
Edit: You are using the installed version, or maybe the ZIP version?
nictau
Post by nictau »
cday wrote: Mon Aug 14, 2023 1:00 pm Where are your setting saved in Tools > Settings > Integration tab?
Hi, thanks.
Yes, I think it has to do with the rights management. But strangely I am working on an Admin account and checked my admin rights on that file.
Some settings are now saved. But especially the specific file colors (settings>files>color for formats) are constantly being reset.
See attached pic.
btw, I am using the installed version.
I'm primarily a Linux user, but pending any support from someone else you could possibly consider trying different Tools > Settings > Integration tab location options.
I have a feeling that I may have seen something similar posted before, and one location option may no longer be accessible even with admin rights.
nictau
Post by nictau »
Thanks for your help. Problem fixed. Admin rights...
nictau wrote: Mon Aug 14, 2023 2:28 pm Thanks for your help. Problem fixed. Admin rights...
Thanks, are you able to provide any more detail to assist anyone else who might experience the same issue?
