Settings - Browser>Thumbnail>Labels tab - update ui
XnViewMP 1.5.3 64bit
General
- swap lists (similar to Settings - unify ui of Toolbar, Shortcuts, Context menu tabs)
- list size is ~ 70/30, but can be same as old one 50/50
- add List title
Mockup B
- group Colors
Re: Settings - Browser>Thumbnail>Labels tab - update ui
This problem is supposed to be fixed in XnView MP 1.5.4. Please check and confirm the bug fix here.
done in 1.5.4,
but its better to:
- aligh top side of lists to the same level
- adjust size/position of color controls
ok
This problem is supposed to be fixed in XnView MP 1.5.5. Please check and confirm the bug fix here.
fixed in 1.5.5
not sure if its worth creating new post
few issues
  • A
    controls should not go to the red oval area
  • B
    'Reset color' button clears 'Custom label' text (it does not save when OK is pressed)
    but button should not clear 'Custom label' anyway
will be fixed
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
fixed in 160
