Browser gets "stuck" on .xmp (Darktable) files when nav back/forth with arrow keys [Solved]
pointy
Post by pointy »
This seems to be a recent problem with one of the newest releases. In a directory with .jpg files and also .jpg.xmp files left there by Darktable (image editor), formerly with older versions of XnView they would be ignored, and I could use the left and right arrow keys to navigate through images in the directory. Now, if I navigate to one of the .xmp files, I see the raw XML in the window as text, and the arrow keys do not work to navigate either backwards or forwards. I have to click to delete that image view to get back to the directory, where of course I can select another image to view.
Is this something I can affect with an application setting?
pointy
Re: Browser gets "stuck" on .xmp (Darktable) files when nav back/forth with arrow keys
Post by pointy »
Oh never mind, if I un-check "Show companion files" it's fine. (I still think it shouldn't get stuck, but whatever.)
Gorgoyle9
Post by Gorgoyle9 »
I have downloaded newest XnView Simple version of app and I can't browse image files with arrow keys on my keyboard. I looked on Settings-options but I can't make XnView to let me use arrows keys for browsing images. I have newely installed Windows 11 OS. I don't know what's the problem. Help.
Gorgoyle9 wrote: Sun Oct 01, 2023 8:26 am I have downloaded newest XnView Simple version of app and I can't browse image files with arrow keys on my keyboard. I looked on Settings-options but I can't make XnView to let me use arrows keys for browsing images.
XnView MP or maybe XnView Classic?
I have newly installed Windows 11 OS. I don't know what's the problem. Help.
Windows 11 has been causing some problems but as a Linux user I'm not familiar with the details...
Gorgoyle9
Post by Gorgoyle9 »
cday wrote: Sun Oct 01, 2023 8:26 am XnView MP or maybe XnView Classic?
Classic one! maybe I should change to MP i don't know.
*EDIT*: MP version works fine! I'll stick with that version. Thank you brah! :D
Re: Browser gets "stuck" on .xmp (Darktable) files when nav back/forth with arrow keys [Solved]
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
Gorgoyle9
Post by Gorgoyle9 »
xnview wrote: Thu Oct 12, 2023 1:11 pm This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
Problem was on XnView Classic!
Nevertheless that, I've checked your new version of MP release and it works fine.
