1.5.5: in 'view mode', using cursor-keys to view previous/next files; stops working upon viewing a TEXT file
kbyork
Post by kbyork »
XnView: MP 1.5.5 64bit
OS: Windows-10 Pro 64bit
Effect:
in Settings > Interface > keyboard: I have 'left/right' = 'Previous/Next file'
When in VIEW MODE, I can scan through my files, using the cursor-keys.
Until I view a TEXT-file; then cursor-keys have no effect.
1. click on a thumbnail, to go into VIEW-mode.
2. use cursor-keys to scan the files.
3. cursor to a TEXT file
Actual behavior (bug): cursor-key no longer allow me switch files. :bug:
Expected behavior : :shock: cursor-keys should continue working.
memo: I can still use 'previous/next file' buttons in the toolbar.
and after leaving the TEXT file; the cursor-keys began working again.
memo: this worked fine in the previous version.
Re: 1.5.5: in 'view mode', using cursor-keys to view previous/next files; stops working upon viewing a TEXT file
This problem is supposed to be fixed in XnView MP 1.6.0. Please check and confirm the bug fix here.
