Uncategorized in Catalog Filter View
4FamilyPhotos
Greetings,
I am a brand new user. I was forced to quit DigiKam because strangely, it was deleting my 'tags' (categories in XnView).
I think I am up and running again but wanted to check to make sure all the deleted tags/categories were restored. So, I clicked on "Uncategorized" and that must not mean what I thought it did because many of my photos are there and they definitely have tags/categories.
SO MY QUESTIONS:
1. What does 'Uncategorized" mean?
2. How can I find my photos that have no tag/category? Thank you!!
SO MY QUESTIONS:
Re: Uncategorized in Catalog Filter View
Files in catalog that have not category
for the full catalog?2. How can I find my photos that have no tag/category?
4FamilyPhotos
If I'm understanding what Catalog means...
I have 1 file of my photos - that's the only file I care about finding any 'categorized' items. When I click on 'uncategorized' it will show me all the files on my computer.
Do you have associated categories to files?
4FamilyPhotos
I'm not sure what you mean. I am only interested in applying categories to my photos which are in on file and then sub files by date. I have applied categories to most of them. In order to know which ones do not have categories applied, I was hoping to find a place where I could separate all my photos that don't have categories. I thought that was the 'Uncategorized' in the Catalog Filter tab, but it doesn't seem so.
I hope I'm not being totally dense. I am brand new to XnView and trying to figure it all out.
4FamilyPhotos
xnview wrote: Tue Oct 10, 2023 2:35 pmFiles in catalog that have not category
I don't see how this is true because I can go to "Uncategorized" and there find photos that definitely have a category attached to it. That's what prompted me to ask the question - what does it mean.
Do you have change 'Match' setting?4FamilyPhotos wrote: Tue Oct 10, 2023 5:35 pm I'm not sure what you mean. I am only interested in applying categories to my photos which are in on file and then sub files by date. I have applied categories to most of them. In order to know which ones do not have categories applied, I was hoping to find a place where I could separate all my photos that don't have categories. I thought that was the 'Uncategorized' in the Catalog Filter tab, but it doesn't seem so.
4FamilyPhotos
I have looked at every setting and can't find anything that says "Math". Can you direct me to where this is?xnview wrote: Fri Oct 13, 2023 1:55 pmDo you have change 'Math' setting?4FamilyPhotos wrote: Tue Oct 10, 2023 5:35 pm I'm not sure what you mean. I am only interested in applying categories to my photos which are in on file and then sub files by date. I have applied categories to most of them. In order to know which ones do not have categories applied, I was hoping to find a place where I could separate all my photos that don't have categories. I thought that was the 'Uncategorized' in the Catalog Filter tab, but it doesn't seem so.
Thank you!
4FamilyPhotos
Thank you for the screenshot. I tried a number of different combinations with that setting but don't really understand the differences. It seems to have no effect on my difficulty - how do I see all my photos that do not have a Category? "Uncategorized" does not seem to be it. Are there other settings I should look at? Or other suggestions to answer my question?
4FamilyPhotos
I'm pretty confused too. I thought my question was a pretty easy one. "How do I filter out all my 'uncategorized' photos so I can see which don't have Categories assigned to them.
If you use 'Global', and click 'uncategories', you should see all files from the catalog that have no associated category
4FamilyPhotos
Thank you for your response.xnview wrote: Mon Oct 16, 2023 9:39 am If you use 'Global', and click 'uncategories', you should see all files from the catalog that have no associated category
Here are my results
to understand the problem, could you send me your xnview.db file?
4FamilyPhotos
I just did via email.xnview wrote: Mon Oct 16, 2023 3:31 pm to understand the problem, could you send me your xnview.db file?
Thank you for your help!
