XnView: MP 1.6.2 - 64 bit
OS: Windows 11 64 bit
XnViewMp bug: Navigation gets stuck on a folder when scrolling through images in the Preview panel using the mouse wheel.
Effect: Focus is lost.
Settings -> Interface -> Mouse -> Set Mouse wheel to previous/next file
Browse to a folder with subfolders & images
Select an image
Move the mouse in the Preview panel
Scroll until a subfolder is selected
Bug: You can't scroll any further to select another image or subfolder, you're stuck.
Expected behaviour: Continue scrolling in either direction, as it is already possible with the arrow keys.
Mouse wheel gets stuck on a folder
Re: Mouse wheel gets stuck on a folder
i can't reproduce. If current item is subfolder, wheel mouse works as expected
Blossoms
I did some more tests, to reproduce it you need to set Preview as a tab. View -> Info panels -> Preview as tab.
ok, i can reproduce nowBlossoms wrote: Fri Nov 24, 2023 8:24 am I did some more tests, to reproduce it you need to set Preview as a tab. View -> Info panels -> Preview as tab.
do you have always the problem?
Blossoms
Yes, the problem still exists in the current version:
1.11.2 [10051] 64-bit (Apr 30 2026) - Libformat 7.239 (Windows)
