XnView: MP 1.6.2 - 64 bit
OS: Windows 11 64bit
I have copied the pictures from my camera to the notebook (SSD). There are about 400 pictures and each picture is between 15-25 MB in size. When I select a single image in the xnView browser and select ALT+M for "Move to..." and start it (click on button "Move"), xnView hangs for a good half minute and nothing works in the program (greyed), although I only want to move a single image to the subfolder of the current image-folder on the same notebook.It would be great if a solution could be found.
Effect: Program hangs ~30 seconds
See description above
1.6.2: "Move to..." [ALT+M] extremly slow / no response of window
marl
Re: 1.6.2: "Move to..." [ALT+M] extremly slow / no response of window
do you have network drives?
Katsumi
Yes, but not used as destination. One time it was active and one time it was not active. Both times same issue.
and 'copy to' has the same delay?
Katsumi
same thing if you copy a low size file?
Katsumi
Oh, yes. For small files too. I use the functions (copy to.. / move to..) first time.
I windows explorer I can move (drag&drop) and copy files instant, there is no delay.
