All custom categories gone XnView MP
derrick
Post by derrick »
Hi there, not sure what happened but I went to the Catalog Filter and noticed all of the custom categories I created for images are now gone. I had about a dozen of them and across my categories had several hundred images catalogued.
The images did not change location and they are still viewable. My Favorites that I created in XnView MP are still however in there.
Was there something that could cause this ? Is there any backup location for where the categories are stored ?
Using v1.6.1 64-bit (Linux)
Re: All custom categories gone XnView MP
In Settings>Path, you have access to xnview.db, could you send me it?
vincentparez
Post by vincentparez »
I have exactly the same problem than Derrick.
I have created tens of customised categories, assigned these custom categories to hundred of pictures.
And this morning, it just gone. No more categories.
By chance, I have exported previously the list of file with the categories assigned. How can I reimport categories and association ?
Attached the xnview.db file and the csv file where I just remove the quotes for txt and change the delimitator (; instead of :)
vincentparez wrote: Sun Feb 04, 2024 10:36 am Attached the xnview.db file and the csv file where I just remove the quotes for txt and change the delimitator (; instead of :)
Really strange, the categories table are like the first time you create the catalog. But the exported file is xml not csv??
vincentparez
Sorry for the misundertanding. By csv file I was talking about the file you can get by the functionnality that export the list of files of your catalog with theit categories (see screenshot)
to export/import categories, you have "File's categories' menu in Categories panel. There is no direct way to import csv
you need to change the csv like exported categories file
