RC1: Slide.exe don't work
Locked
Post by Guest »
The slide show exe files don't work. When I run it nothing happens and the process stays in the backround with 100 CPU usage.
marsh
Post by marsh »
Confirmed.
Xyzzy
Post by Xyzzy »
Works for me in rc1.
X.
ckv
Re: RC1: Slide.exe don't work
Post by ckv »
Anonymous wrote:The slide show exe files don't work. When I run it nothing happens and the process stays in the backround with 100 CPU usage.
This was me.
Xyzzy what os you are using? And could you try this [EDIT] (slide show what I made and my xnview.ini).
Edit:
Some of the slide shows what I create works, but when I close it by doubleclicking the process stays in the backround. I will make new topic for this.
Post by Guest »
With your file the problem is present.
XP Pro SP2.
X.
This was me.
Xyzzy what os you are using? And could you try this (slide show what I made and my xnview.ini).
Edit:
You have the problem with 2 pictures?
marsh
Post by marsh »
xnview wrote: You have the problem with 2 pictures?
I also have problem with slide.exe just using 2 pictures. I haven't been able to get it to work yet.
ckv
Post by ckv »
xnview wrote:You have the problem with 2 pictures?
Yes. I hardly get any exe slide shows to work.
rumpanzle
Post by rumpanzle »
I haven't been able to create a slideshow under XP SP2 with latest patches. .exe and .scr wont work, regardless of the number of pics I use.
This was me.
Edit:
Could you sned me an email, i'll send you the correct slide.exe to check?
ckv
Post by ckv »
xnview wrote:Could you sned me an email, i'll send you the correct slide.exe to check?
OK. To webmaster address right?
ckv
Post by ckv »
Seems to be fixed in RC2. More confirmations please.
marsh
Post by marsh »
ckv wrote:Seems to be fixed in RC2. More confirmations please.
It now crashes in RC2!
1. Create a slide.exe.
a. Use random order.
b. Use advance with keys/mouse.
c. Show information disabled in options.
2. Press "i".
3. *Crash. It also crashes immediately with show information on.
My Show information data:
A single line (imported ini from v.1.80.3) with:
<File Index> <Filename With Ext> <Width>x<Height> <Size KB> <Zoom>
marsh
Post by marsh »
Fixed. RC3 No crashes! :)
Locked
