unmarked catgories
Ulli
unmarked catgories
Post by Ulli »
How can I view images that are not categorized?
Thx
Ulli
Re: unmarked catgories
In categories filter panel, you can select 'Uncategorized'
Ulli
Post by Ulli »
Sorry, which category filter do you mean exactly?
the panel called 'category filter'
Post by michel038 »
or "Catalog filter" :D
houps right "catalog filter' :D
Ulli
Post by Ulli »
If I select uncategorized, the display always changes to the top folder level. If I then select folder 2023, for example, “uncategorized” is left. I would like to check any of my folders to see if there are files without a category.
in 'Uncategorized', you have subfolders too
Post by michel038 »
You must also check settings in the "Match" menu, at the top of catalog filter pane.
Ulli
Post by Ulli »
xnview wrote: Tue Jan 23, 2024 9:21 am in 'Uncategorized', you have subfolders too
Yes, I saw that. Unfortunately "uncategorized" disappears when I open a subfolder.
Ulli
Post by Ulli »
I am unable to search uncategorized in a subfolder. As soon as I click uncategorized, everything from the main "Images" directory is displayed (uncategorized).
Re: unmarked catgories : solved v1.6.5
Post by michel038 »
Right, the "Match > Current folder" doesn't work :bug:
Waiting for a fix, you can :
- View the chosen folder content in the browser
- Use Tools> Search menu
- Let filename empty
- Tick only "use catalog", and "recursive" if needed
- Add a condition : "categories" "is" and let the field empty
- Search ...
Close search dialog, view another folder , Ctrl F ... etc ...
michel038 wrote: Tue Jan 23, 2024 8:48 pm Right, the "Match > Current folder" doesn't work :bug:
how that?
Re: unmarked categories in current folder
Post by michel038 »
- Display a folder containing X photos without categories
- Catalog Filter , Match > Current folder
- Select "Uncategorized" ...
You will get all uncategorized photos from the entire catalog , instead of getting X photos from current folder. :bug:
With tagged photos, it works fine, only tagged photos from current folder are displayed
'Uncategorize' & 'All' doesn't use this setting, it's on full catalog
