Folder label with last accessed date
Thargaris
Post by Thargaris »
is it possible to label a folder thumbnail with the last accessed date ? I've configured the settings like the attached image but the last accessed date is not shown for the folder thumbnail, which only shows its name. The last accessed date is only shown for files thumbnails inside it.
Thanks
Thargaris
Re: Folder label with last accessed date
Post by Thargaris »
Hello again,
I've just found this recent thread about the issue viewtopic.php?t=46518 . I've XnView MP 1.6.4 but the date label is still missing from folders thumbnails.
Thargaris
Post by Thargaris »
I've just tested 1.6.3 portable and the date label on folders is still not there. Maybe I'm missing some options, currently I'm using 1.6.4 portable.
I hope you can help me.
Thanks
Thargaris
Post by Thargaris »
Well, file created date and file modified date labels are shown on folder thumbnails, not so for custom label "Accessed date"
Thargaris
Post by Thargaris »
You're welcome.
Regards
This problem is supposed to be fixed in XnView MP 1.6.5. Please check and confirm the bug fix here.
Thargaris
Post by Thargaris »
Hello, I confirm that on 1.6.5 version the bug is fixed.
Regards
