Would it be possible to add a context menu option to ad a photo, or a selection of photos, to an Album. I realize that photos can be dragged, but I think a context menu option would be helpful. The album feature is not very discoverable, at least it wasn't for me, but it is a great feature.
Thanks for all the work you have put into XnView, it is appreciated.
Gord
Add to Album context menu option.
therealgord
jkm
Re: Add to Album context menu option.
Agreed.
This really needs to be done. There should be a right-click option, and a toolbar dropdown in the browser and viewer.
This was part of the original request for Albums back in 2013, 12 years ago.
Having drag and drop be the ONLY way to add to Albums is very cumbersome.
jotess
Could somebody give me a hint where I can find the albums, how to create one? I read your post in that way that there must be a UI element visible to drag images to. I can't find anything.
I have altered my GUI, probably before the album feature was introduced. I have looked into the configuration options if I can add something back by hand. But I only found 3 commands that can be added to the toolbar that are applicable only if an album already exists.
Do I have to reset my GUI or do a clean install?
jkm
It's better to post questions in General Support, as it is more likely to be seen; this board is for suggestions and gets fewer views.
Albums are to be found in the Catalog Filter pane. From the menu, select View->Panels and ensure Catalog Filter is checked to enabled it. Once it is enabled you can move it around. Depending on how you have rearranged your interface, it may be inconspicuous as it may have been reduced to a tab.
Albums are a tree item in the Catalog Filter pane. Once you find them and right-click on the Albums tree, the rest should be obvious.
Since you have reactivated this thread, I'll mention that the suggestions made earlier in this thread have been addressed. As of XnViewMP 1.9.6, the following improvements have been made:
I'll also mention Smart Albums were also implemented in 1.9.6. Read more about them here:
viewtopic.php?t=49948
- Albums in the catalog tree now have comprehensive right-click options, to add, delete, rename, etc.
- Images can be added to albums via the right-click context menu. Right-click on an image or multiple selected images, and Select Metadata->Add to Album
- Images can be added to albums from the main menu as well: Metadata->Add to Album
- The Add to Album menu is now dynamic, and will reflect the current list of albums without having to restart the program.
- There is now a option to remove an image from all albums.
- Collections have been implemented. A "Collection" is an album containing other albums. You can create a "new album" in the tree, and move existing albums into it with drag and drop, or create new albums inside it.
jotess
Thank you, this was a great help!
GracyScott
Big +1 for this. Drag and drop is fine for a couple of files, but when you're managing a large library, it's easy to 'miss' the target folder or just lose track of where you're dragging. Having a simple right-click 'Add to Album > [Album Name]' would make the workflow so much faster.
jkm
Thanks for the enthusiasm, but since you're +1-ing this and saying it “…would make” you evidently didn’t really read the thread.GracyScott wrote: Wed Dec 17, 2025 8:45 am Big +1 for this…. Having a simple right-click 'Add to Album > [Album Name]' would make the workflow so much faster.
Please read my post from 7 December and you’ll see that that feature, and many others, already were added to the app.
Try actually exploring the right-click menu.
alee001
Just passing by...
A album is essentially a folder. Naturally, to move a picture to a different album, you can use Alt+M; to copy a picture to a different album, you can use Alt+C; but to categorize a picture into different albums, why not use tags?
jkm
Because in the context of image metadata, tags have a specific application and storage mode; they are keywords, stored in specified ways in metadata blocks or in sidecar files; they are not Albums, and are distinct from them. Certainly, one could simulate Albums using tags and filter by them, but then you create the new problem of distinguishing Album-tags from non-Album-tags, and the second problem that the Album-tags, which are now in the file metadata, would be interpreted wrongly by any other software. It’s not an appropriate solution. It’s like trying to use Ratings as Albums. They’re different things.alee001 wrote: Tue Dec 23, 2025 5:39 am … but to categorize a picture into different albums, why not use tags?
alee001
Thank you for your explanation. Unless MP can set folder properties like Windows (such as music, videos, albums), I am just suggesting a simple solution and I understand the difference.jkm wrote: Tue Dec 23, 2025 6:17 amBecause in the context of image metadata, tags have a specific application and storage mode; they are keywords, stored in specified ways in metadata blocks or in sidecar files; they are not Albums, and are distinct from them. Certainly, one could simulate Albums using tags and filter by them, but then you create the new problem of distinguishing Album-tags from non-Album-tags, and the second problem that the Album-tags, which are now in the file metadata, would be interpreted wrongly by any other software. It’s not an appropriate solution. It’s like trying to use Ratings as Albums. They’re different things.alee001 wrote: Tue Dec 23, 2025 5:39 am … but to categorize a picture into different albums, why not use tags?
jkm
A solution to what problem? A rhetorical question. If you read the thread, you’ll see that the OP's specific request has been addressed, and the requested features have been added to the application. So there is no outstanding problem, nor any solution required. And as I tried to communicate, using tags is not an appropriate substitution for Albums, especially in an application that supports albums, so it’s not even really a solution at all for what was being discussed here. And the “folder properties” you mention are not germane to the questions raised in this thread.
Thanks for your interest.
alee001
I'm just looking at the question simply; perhaps the poster just wants to create a right-click shortcut to easily save pictures to various albums.jkm wrote: Tue Dec 23, 2025 9:08 amA solution to what problem? A rhetorical question. If you read the thread, you’ll see that the OP's specific request has been addressed, and the requested features have been added to the application. So there is no outstanding problem, nor any solution required. And as I tried to communicate, using tags is not an appropriate substitution for Albums, especially in an application that supports albums, so it’s not even really a solution at all for what was being discussed here. And the “folder properties” you mention are not germane to the questions raised in this thread.
I only consider albums as virtual folders, different from tags.
