Settings - lists - unify behavior / improve UX
XnViewMP 1.7.2 64bit
Settings - lists
there are multiple lists in Settings with different behavior
unify lists behavior / improve UX
Toolbar
  • combobox
    • make Viewer selected by default
      as this is the most common mode
  • left list
    • add shortcuts/mouse
      - del - to remove item
      - mouse double-click - to remove item
  • right list
    • add header (same as in Shortcuts)
      so its possible to sort items by command name
      - mouse double-click - to add item
      - mouse drag&drop - to add item from right to the left list
    • (optional) allow multiple items selection
Context menu
  • combobox
  • left list
      - del - to remove action
  • right list
Shortcuts
  • combobox
  • list
    • improve filter
      - add shortcut combination to the search string
      there are several ways to implement this, the easiest is to add a 5th invisible column with the text "Action&Shortcut&Command name" (eg AverageCtrl+3cmd_rating3)
      so when "Ctrl" is typed - it will show all shortcuts with Ctrl
    • add shortcut
      - del - to remove shortcut
Labels
  • left list
      - mouse drag&drop - to reposition items
  • right list
    • add filter
Related
