Switching modes selection
8bit
Post by 8bit »
In settings/interface/switching modes I have everything set to Browser<->Fullscreen. When I double click on an image file in explorer XNView MP displays the image at full screen. However, when I double click (or press enter) it displays the image with the application interface (toolbar) (not sure how this mode is called). I have to click on the browse button to get the browser. After I do this, the interface correctly switches between full screen view and browser when I double click until I close the application. When I run it again I have to repeat the process.
Re: Switching modes selection
8bit wrote: Wed Oct 30, 2024 5:27 pm In settings/interface/switching modes I have everything set to Browser<->Fullscreen.
the correct name of this switching option is "Browser <-> Fullscreen | Viewer <-> Fullscreen"
8bit wrote: Wed Oct 30, 2024 5:27 pm When I double click on an image file in explorer XNView MP displays the image at full screen.
there is another setting responsible for opening mode:
set "Start with file" to "Browser - Fullscreen" (Settings > General > Startup)
with these 2 settings the only one way to get into Viewer mode - Open command
if you have any issues - use latest version and delete your settings file (xnview.ini)
8bit
Post by 8bit »
user0 wrote: Wed Oct 30, 2024 6:20 pm there is another setting responsible for opening mode:
Perfect, this fixed it. Thanks a lot.
