Transparency in AVIF
faisal0997
Hey I'm trying to convert some PNG images with transparency into AVIF for the web but it seems XnConvert doesn't support transparency for AVIF's or am i missing some setting somewhere to allow this? Any guidance would be greatly appreciated thank you!
Re: Transparency in AVIF
alpha channel is supported by AVIF
faisal0997
Hey Pierre thank you for responding! I know that AVIF supports alpha channel transparency but my image always comes out with a black background, I can however go into actions and extract the alpha channel of the image so i believe its there? Perhaps i'm still overlooking something so any further help would be appreciated!
please send me the source image file
faisal0997
Sorry for the delay here's a link to the image! https://we.tl/t-kN1T05shEr
sorry but link is not availablefaisal0997 wrote: Mon Dec 30, 2024 1:35 pm Sorry for the delay here's a link to the image! https://we.tl/t-kN1T05shEr
rctneil
Any updates to this?
I have 3 AVIF's with transparency but when I export as PNG, the transparent areas turn black?
Images are in this zip file: https://a.dropoverapp.com/cloud/downloa ... 455c78aae4.
Thanks
Neil
Thanks
Neil
marsa
I just tested your images and transparency is recognized and kept when converting to PNG with the latest version (1.112.0). Maybe you are on an older version of the program? If not, please describe your scenario, or provide screenshots of "Actions" and "Output" tabs.rctneil wrote: Fri Jun 26, 2026 8:00 pm Any updates to this?
Thanks
Neil
rctneil
I apologise,
I'm trying to convert them to webp files. My settings are as follows:
it works on macOS, intel?
rctneil
Yeh, I'm in MacOS. Latest app version, latest OS version. MacBook Pro M1 Pro.
Here's my resultant image.
Very weird.
Very weird.
Strange, i've tried on my M1 Pro, and output webp is 32bits not 24bits. without resize action?
rctneil
I've tried a bunch of things and no change. Always a black background.
I tried disabling the resize action. No change.
On the Settings tab, there is "Preview background colour" is this to do with it?
use new version of XnConvert
there was error with 32bit avif shows as 24bit (transparency shows as black)
rctneil
Spot on! Working now!
Thankyou
Thankyou
