Hi, not sure if this has been reported before (did a search but didn't find anything).
If I select a folder icon (in the browser view) and open the contextual menu, the "open with" actions won't work.
In fact, I would expect the "open" action (again, contextual menu when on the folder icon) to actually enter into the folder, in the browser view, but it is also ignored.
Tried also with the main menu > Tools > Open / Open with, with the same results.
I understand that "open with" actions are primarily intended for images, but I think it would be desirable to get them working also on folders. In my case, I could open 'Media Player Classic' from XnView to listen a whole album while browsing my photos.
Thank you very much for your time. Great work!
Aristarco
XnView 1.82 <x>
"Open with" on a folder
Dreamer
marsh
The fix may be about "open" not working on folder rather than new feature. We'll see.Dreamer wrote:Right, but it doesn't work good also for files...helmut wrote:Simply using the same list of programs for files and folders does not make too much sense.
There are few posts about it, but it's part of large topic, so I'll start new topic in Requests forum...
marsh
Open now works on folders. Yay. Fixed?marsh wrote:The fix may be about "open" not working on folder rather than new feature. We'll see.Dreamer wrote:Right, but it doesn't work good also for files...helmut wrote:Simply using the same list of programs for files and folders does not make too much sense.
ckit
