If I crop an image and then rename it, the cropping is undone.
From my point of view, it should be the case that the cropping is retained.
My version is 1.8.3 64 bit (Windows)
renaming after cropping undoes cropping
svennbg
Re: renaming after cropping undoes cropping
the problem is that you rename the file without saving it first
svennbg
Yes, of course, but it would be very helpful if there was at least a confirmation prompt here.
Something like this:
You have made changes to the photo.
Should the modified version be renamed?
Or at least:
Attention:
If you rename the photo, any unsaved changes will be lost.
Or at least:
Attention:
it's better to implement renaming-dirty-file-without-reloading functionality, eg like in vscode
