Can cache remove NON-existing directories automatically ?
Nelson
Post by Nelson »
Hi there,
Now Cache-Optimization can remove non-existing files, but keep the directory's name.
Can you remove the empty directory, too?
For example:
1. Browser a directory called "C:\test", then you can see the detail in Cache.
2. Delete the directory "C:\test" and then use Cache-Optimization function.
3. You still can see the "C:\test" in Cache detail, but it shows 0 image.
What I asked is that can it also remove the "C:\test" entry in Cache detail ?
Re: Can cache remove NON-existing directories automatically
Nelson wrote:Hi there,
For example:
Ok, i'll fix it
Post by Guest »
For example:
Ok, i'll fix it
It doesn't seem to be fixed in 1.82 RC3.
Or, will you fix it in the future version ?
Thanks for your reply :D
For example:
Ok, i'll fix it
Yes in a 1.83
ckit
Post by ckit »
Postphoned.
