Import and sort window issue - too big with mint 21
Gwenael Q.
Post by Gwenael Q. »
Completely new to Linux (Mint 21), where I have the following issue :
The Import and sort window is too big (see attached image) and the OK button at its bottom is out of screen, and I didn't find any scroll bar. Hence I can not use this tool... :shock:
Seems to me that if font where smaller I could see the whole window.
Any help is welcome !
XnV 1.8.3
Re: Import and sort window issue - too big with mint 21
Gwenael Q. wrote: Wed Mar 05, 2025 5:46 pm The Import and sort window is too big
well, you have 1366x768 resolution
anyway, Import - make import modes explicit
Gwenael Q.
Yes. But same issue with other resolutions...
Thanks for your help.
Gwenael Q. wrote: Wed Mar 05, 2025 6:49 pm
what resolutions and what DPI scale
Gwenael Q.
1280 x 720 and 1366x768.
I don't know exactly what is dpi scale but the setting "monitor scale" is 100%
Gwenael Q.
For those having the same kind of problem, I found the following workaround :
Alt + clic-and-drag allows to access all the interface hence makes the window usable
