- Take a screenshot.
- Open it in XnViewMP and go to File ⭢ Save as…
- The dialog briefly appears, and is immediately replaced by An error occurred during saving!
Saving image…
Can’t Save AVIF on macOS
zecanard
- Skype: zecanard
I haven't been able to save files to AVIF on macOS. This affects 1.8.6 and 1.8.7. I haven't tried in earlier versions.
Re: Can’t Save AVIF on macOS
i'm not able to reproduce with 1.8.7, which MacOS version do you have?
zecanard
- Skype: zecanard
I’m running macOS Sequoia 15.4 RC, on a 2019 Intel iMac, but this was happening in 15.3 as well, if I remember correctly.
ok currently AVIF output is only available on ARMzecanard wrote: Fri Mar 28, 2025 8:07 pm I’m running macOS Sequoia 15.4 RC, on a 2019 Intel iMac, but this was happening in 15.3 as well, if I remember correctly.
zecanard
- Skype: zecanard
Ah, okay. Thanks for the update. Is an update possible to encode on Intel Macs as well?
i'll checkzecanard wrote: Sun Mar 30, 2025 7:20 am Ah, okay. Thanks for the update. Is an update possible to encode on Intel Macs as well?
