Sometimes I need to change sorting of files in XNView MP (1.8.6 Linux .deb) file browser yet I prefer image viewer (when i doubleclick image to view in a full screen) to display always alphabetically. I continuously forget to switch back to alphabetical.
I think that I have been told it is not possible to separate browser and viewer sorting, which is bad.
So I have set alphabetical sorting in browser, yet when i double-click image to open viewer and hit arrows left/right, it displays different images than the browser.
Browser under green arrows icon (sorting) has sorting by "Name", "Ascending", "Name - Alphabetic order". I have tried also other combinations of alphabetic orders but without the luck.
When I go to settings, search for "sort", there is "File list" page, where is ticked only "Folder always sorted alphabetically" in Sorting section. I have also tried various combinations here.
File names does not seem to contain any special characters.
UPDATE: I have just noticed that the image files are missing extension.
Similar without solution: How to change "Sort By" quickly while in image viewer?
File browser has different sorting of files than viewer, how to fix it?
postcd
Linux user, .deb package. Use private services like Proton.me, not surveillance services like Google, Meta.
postcd
Re: File browser has different sorting of files than viewer, how to fix it?
Despite file has no extension, it is displayed correctly by Xnview, XNview should also browse such extension-less files properly sorted. It is not the case. Here you can try to reproduce on these files.
In Viewer which order do you have?
postcd
Viewer? I read that the browsing happens based on which column header I click in Browser (File -> Browser). My order there alphabetical A->Z.
1) File -> Browser
2) View -> Sort by -> Name, Ascending, Name - alphabetic order
I have been criticizing how Xnview is browsing files: viewtopic.php?t=46199
