Cannot open AI file
SoCu
Cannot open AI file
Post by SoCu »
Hi, I have seen some posts commenting on this problem, but it is many years old, yes I can see the thumbnails and open the EPS files, but with all the *.AI files I cannot see the thumbnails, and when I try to open them it shows an error “Cannot load file”.
I have installed the Ghostscript extension, and set the paths to the BIN and LIB folders in the environment variables.
As of today, is there any problem displaying *.AI files, or am I configuring Ghostscript wrong?
And from XnView Shell Extension, it shows this extension to be able to convert this type of files.
sample AI files;
https://drive.google.com/file/d/1CHJ5Wl ... sp=sharing
https://drive.google.com/file/d/1Dzrz0Z ... sp=sharing
https://drive.google.com/file/d/1Fe6eQD ... sp=sharing
https://drive.google.com/file/d/1g-Mi8a ... sp=sharing
Thank you.
Re: Cannot open AI file
please send us a sample file
SoCu
Post by SoCu »
Hello Pierre, I have put them in the first post, I have put several of them with different sizes.
SoCu wrote: Tue May 06, 2025 3:58 pm Hello Pierre, I have put them in the first post, I have put several of them with different sizes.
i have not rights for links
SoCu
Post by SoCu »
Ok, that's it, sorry, I marked all four and gave access to all, but I take it only one link.
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
SoCu
Post by SoCu »
Thanks Pierre, I'll check later, I'll be away for a week.
SoCu
Post by SoCu »
Hi Pierre, I have already been able to check, and now they are all displayed, very good, thank you very much.
