Here is screenshot from XNView MP Browser. Couple of improvement suggestions:
- 24bit shows automatically as 16M (colors). IMO showing the colors here might be a bit of old fashioned thinking as majority of material out there is 16M anyway. And even in 24bit pics are variations like srgb, BT-709 and other color gamuts like the one of Apple, hdr, etc.. Also as you see for 16bit png file is says 48bits.
Suggestion of better way to do:
- 1. modify info to be coherent so that it is always either total bit depth (24, 32, 48, 64, etc..) or per channel bit depth (8, 16, 10, 12, etc..)
- 2. make in addition for properties column new colums like: CHANNEL BIT DEPTH (8/16/8/10/12/14), TOTAL BIT DEPTH (24, 32, 48, 64, etc...), CHANNEL CONTENT (RGB, RGBA, CMYK, Monochrome or B/W). Also new column is good as sometimes you would only want to browse only 16 bit pics and it would be possible to sort by bit depth.
bit depth as column in browser
golemus
Re: bit depth as column in browser
+1
also some HEIC files sometimes show incorrect BPP info
1st option - WxHxBitPerPixel, to have same format for Filelist column and Properties in Browser/Viewer Statusbargolemus wrote: Mon May 05, 2025 2:35 am - 1. modify info to be coherent so that it is always either total bit depth (24, 32, 48, 64, etc..) or per channel bit depth (8, 16, 10, 12, etc..)
