1.9.1 - browser - fullscreen - video file not shown
XnViewMP 1.9.1
Browser - fullscreen
video file not shown (issues appeared in 1.9.0)
1. open folder with test files in Browser
test_browser_fullscreen_blank_video.zip
(5.33 KiB) Downloaded 195 times
2. select video and press F11
OR
2. select any image and press F11
3. navigate to video file(s)
Viewer will be blank
Related
Re: 1.9.1 - browser - fullscreen - video file not shown
with default ini?
yep, default ini
same issue if startup - Browser-Fullscreen
no issue if image opened in Viewer(Viewer-Fullscreen) and navigated to video
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
fixed in 192
B.Douille
Post by B.Douille »
For whatever reason it seems the problem is back :?
I just tried on 2 machines, Win11, MP v1.9.2 installed and also one unzipped (new ini file) and the videos either don't play at all or just a blank screen.
I'm sure it worked at least on one machine I tested the dual screen : https://newsgroup.xnview.com/viewtopic.php?t=49214
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
B.Douille wrote: Sat Jun 14, 2025 6:07 pm videos either don't play at all or just a blank screen.
try to install/update WIC codecs
B.Douille
Post by B.Douille »
On today's issue it's only in a normal slideshow.
Videos are played normally in all other context (preview in browser, edit mode, fullscreen and quick slideshow). This suggest a more programatical issue than a codec.
Today I tried also to change useInternalVideoPlayer=true to false but it's the same. Both the internal and external players are able to manage videos. I can't believe the Windows codec are being part of an issue impacting only the normal slideshow.
If some codec need to be updated, this should be checked as part of the installation wizard. If needs, the user should be informed some packages will be updated as part of the process. I won't touch them.
While the root cause can be similar, today's issue is a bit different from original report, where it didn't play in full screen mode and so in quick slideshow as well as in normal slideshow (I noticed the previous deficiency on Friday 30th while I displayed a slideshow with a mix of pictures an videos for an family event).
sunclad
Post by sunclad »
I'll second for HEIF and WEBP formats when and if possible as I am getting an increasing amount of these and I have to jump through some hoops sometimes to get these to convert of rother people and usages.
Worse case I open and screen shot it and resave it otherwise.
Thanks.
Great programs. I prefer Classic over MP at this time.
B.Douille
Post by B.Douille »
B.Douille wrote: Sat Jun 14, 2025 10:42 pm On today's issue it's only in a normal slideshow.
Tested again with latest v1.9.4 using a dozen of pictures and videos. The videos only shows a uniform screen of my preferred background color and goes to the next picture after the delay.
do you have issue with example files from this post?
If NO - make a new post with your sample files
B.Douille
Post by B.Douille »
Sorry, I didn't catch this topic was closed, fixed and only related to full-screen mode.
I created a dedicated one: Slideshow - video file not shown, blank
Best regards
