Switching from XnView Classic to MP
herr_k.
Post by herr_k. »
new pc and must update, because the classic does not have support for avif?? thats strange..
i always used it in portable mode, also because i need it on an usb drive.
i tried to just copy over the old xnview.ini, which did nothing. can i somehow import all the settings? would be annoying to have to configure it all again after years..
and also in the directory, which size is 3 times the classic(!) can i just delete the files i don't need like qt5 (quicktime?),
is there a list, which files are for what so i can choose a minimal install?
thanks
Re: Switching from XnView Classic to MP
herr_k. wrote: Thu Jun 19, 2025 6:20 pm i tried to just copy over the old xnview.ini, which did nothing. can i somehow import all the settings? would be annoying to have to configure it all again after years..
Settings of Classic are not compatible with MP
Qt5 is not Quicktime but UI's API, you can only delete Plugins or language folder
herr_k.
Post by herr_k. »
i would rather stay in the classic then.. any way to show these avif somehow ? why there is no plugin for this ?
