XnView: MP 1.9.2 - 64 bit
OS: Windows 10 64bit
Video file is copied instead of being moved.
1. Have two instances of XnView MP open with a browser view.
2. At the first instance, move the cursor bar to a video file and press ctrl-X.
3. Go to the second instance, which shows another directory at the same drive, and press ctrl-V.
Actual behaviour (bug):
For a few seconds, nothing seems to happen.
Next, the progress bars show that the file is being moved. This takes again a few seconds (depending on the size, of course).
Finally, a dialog is displayed with the title "Copy Warning" and the error message "Cannot remove source."
Retrying doesn't seem to help.
Expected behaviour:
Movie file is moved to the new directory pretty much instantly since its contents do not need to be copied. Moving succeeds and the file is removed from the original location. No error dialog is displayed.
1.9.2: Video file moving fails
solcuerda
Re: 1.9.2: Video file moving fails
Yeah seems to be that XnView is locking files and then can't delete the original file once it has been copied across to the new location. A Windows specific issue.
Asam
This bug also seems to break file system integrity, which I find rather disturbing.
Asam
I'm inclined to think that the problematic decision occurs before the file has been copied, since its contents should not be copied in the first place, the file should just be moved within the file system.
venik
I have the same issue, see here
viewtopic.php?t=50056
