1.9.8 Move operation does not remove video from source
venik
Post by venik »
XnView: MP 1.9.8 – 64 bit
OS: Windows 11 – 64 bit
Short description:
The application cannot move a video file when it is selected in the file browser, regardless of whether autoplay is enabled or disabled:
move operation copies video files but does not remove them from source
Effect:
The user is unable to reorganize or manage video files using the Move command. Video files remain locked or unmovable while selected, forcing the user to use external tools to delete them.
1. Open a folder containing one or more video files.
2. Select a video file in the browser (autoplay enabled or disabled).
3. ctrl + M to try to move the video selected.
Actual behaviour (bug):
The video file cannot be moved while it is selected.
This happens both with autoplay enabled and disabled.
Error message: "Cannot remove source" is shown.
Expected behaviour:
A video file should be movable,
Thank you in advance!
Love XnView! ❤️
Re: 1.9.8 Move operation does not remove video from source
are you able to reproduce each time?
venik
Post by venik »
xnview wrote: Fri Dec 19, 2025 9:03 am are you able to reproduce each time?
Yes systematically
Strange i'm not able to reproduce :(
is it possible to have a screencast?
jkm
Post by jkm »
Venik, your problem might be happening because Windows Explorer locks the file when it is probing metadata and/or creating a thumbnail, and that can take a long time with video files; it’s very annoying.
To test for this condition, first, temporarily disable your antivirus to prevent file scanning, then do the following using the command line only:
1. Create a new directory, like c:\test
2. Copy an existing video file into that directory.
Do NOT try to view the folder/directory or file in explorer in any way. Don’t even have a folder view of C:\ open.
3. Now try performing your operation on that file using XnViewMP.
There should be no opportunity for Explorer to lock the file doing the above.
You can also download from Microsoft the Sysinternals utility "Handle" to learn what process has an open handle lock on your file...
https://learn.microsoft.com/en-us/sysin ... ads/handle
venik
Post by venik »
jkm wrote: Sat Jan 31, 2026 11:05 pm Venik, your problem might be happening because Windows Explorer locks the file when it is probing metadata and/or creating a thumbnail, and that can take a long time with video files; it’s very annoying.
Hello, sorry for the late reply.
I don’t have any antivirus installed.
I can confirm the described scenario. However, it is quite common to move a video file right after watching it, regardless of whether autoplay is enabled or not.
Has this issue been reproduced on your side?
PS: attached you can find a screenshot
jkm
Post by jkm »
venik wrote: Mon Feb 23, 2026 10:16 pm I don’t have any antivirus installed.
On Windows 11? So you removed or disabled the built-in “Windows Defender”?
jkm wrote: Sat Jan 31, 2026 11:05 pm To test for this condition, first, temporarily disable your antivirus to prevent file scanning, then do the following using the command line only:
Sorry, I don't understand what you mean by "confirm the described scenario". Are you saying you do NOT have the problem when you follow my steps above, or you DO?
I suggest you download the utility I mentioned and find out what process is locking the file.
venik wrote: Mon Feb 23, 2026 10:16 pm Has this issue been reproduced on your side?
No i can't. Do you have the issue with little video file?
