Batch convert 'Export for NConvert' error in exported code
McBluna
Post by McBluna »
Version used: XnView MP 1.9.2 64-Bit
actual behavior
In case, I choose Lossless for WEBP, the Export for NConvert function export the WEBP quality setting to the batch file.
nconvert -out webp -q 75
changing quality setting to 87 and back to Lossless
nconvert -out webp -q 87
expected behavior
nconvert -out webp -q -1
Best regards
McBluna
Re: Batch convert 'Export for NConvert' error in exported code
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
McBluna
Post by McBluna »
Sadly, I cannot confirm it's fixed.
Version used: XnView MP 1.9.3 64-Bit
"Export for NConvert" with filename
nconvert -out webp -q 100"C:/Users/McBlu/OneDrive/Bilder/dissolution.png"
  • Quality is set to 100 instead -1 for Lossless
  • blank is missing between value and filename
  • extra blank at the end of filename
reopened
This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
McBluna
Post by McBluna »
Hey Pierre,
Thank you. I can confirm that the quality settings from the WebP configuration are being correctly applied to the generated NConvert script.
nconvert -out webp -q -1 "C:/Users/McBlu/OneDrive/Bilder/dissolution.png"
nconvert -out webp -q 100 "C:/Users/McBlu/OneDrive/Bilder/dissolution.png"
nconvert -out webp -q 90 "C:/Users/McBlu/OneDrive/Bilder/dissolution.png"
nconvert -out webp -q 0 "C:/Users/McBlu/OneDrive/Bilder/dissolution.png"
Best regards
McBluna
