Deleted files don't go to recycle bin
romekromekromek
Post by romekromekromek »
I have current Linux Mint and Xnview MP 1.9.2 (AppImage) and when I delete files they don't go to recycle bin,
I attach screen with my settings. Delete prompt works but it doesn't send files to recycle bin.
KPAH
Re: Deleted files don't go to recycle bin
Post by KPAH »
I second that.
I use _the same_ XnviewMP 1.9.2 as an appimage with portable home and config folders on identical Arch(Manjaro) instances. The only difference is filesystem Linux is installed on - ext4 and btrfs.
On ext4 deleting sends the files to Trash folder. On btrfs, they do not go to Wastebin even if they are deleted on an NTFS partition.
romekromekromek
I have ext4 file system and still have problem with sending files to trash...
david3
Post by david3 »
I'm having the same problem on Debian. Except, when I delete the file on the system drive, it sends it to the recycle bin, but on an attached USB hard drive, it doesn't. Both are using the BTRFS file system.
